I'm getting in on this thread a little late, hope it still helps... First, if you're planning on using the tractor on the rest of the land anyway, get a little 3-point disk, maybe 6 ft, that should be a good match for the little Ford. If it's not cutting well enough, you can throw a little weight on it. Go over it (and over it, and over it...) until you get it ground up fine for a good seedbed. You don't have to plow it deep for grass, but you'll want to get it as smooth as you can for the yard. If you have a lot of rocks or trash, the rock rake is a good idea, they're handy. I've used one to clean out our hay barn. The bedsprings are a good idea for a harrow, but old tires are much easier to find. Tie the tires together with some good rope, in the shape of the Olympic rings - 2 in the front and 3 in the back. Pull it with a chain behind the tractor, at a fairly brisk pace to throw it around a little. use a long enough chain that it won't raise up in the front when you pull it. Throw out your seed, then go over it with the tire-harrow again to cover it up, don't cover it with the disk, it will be too deep. Then just water it and watch it grow. I did this last year at our house and I've got full coverage this year with common bermuda. Oh, and on the stumps - PLEASE try some other way. Unless they're pretty small stumps, that's an awfully light tractor to try to pull stumps with, and easy to flip. Be sure to hook the chain as low as you can, preferably on the drawbar. DON'T hook it around the rear end, that's too high and it makes it too easy to turn over. Have fun with that Ford, it's a great machine, first tractor I ever drove! Kerry
