Bromegrass Rate
John in IN
03-16-2004 16:46:57
I am going to spring seed bromegrass in first year alfalfa that I spring seeded in winter wheat last spring. I cut the wheat in July and I got one cutting of hay off last Sept. I want to seed some bromegrass to fill in the thin spots. I was told it is a good mix with alfalfa. My question is how many pounds per acre? Seeding it in late March a good time to seed brome grass in mid-north Indiana? Any info appreciated. Thanks, John
52BMAN
03-17-2004 06:08:24
 Re: Bromegrass Rate in reply to John in IN, 03-16-2004 16:46:57
I live in Central Iowa and we seed brome in mid April after last frost. Use 3-4 lbs./a when seeding into alfalfa. Good Luck.
John in IN
03-17-2004 17:44:31
 Re: Re: Bromegrass Rate in reply to 52BMAN, 03-17-2004 06:08:24
Thanks, I am going to try that. I will keep you posted on how it turns out.
jackel,ind
03-16-2004 21:15:32
john, i cant help you but i am trying to start raising my own hay too.where are you located at im in galveston,about 6 miles north of kokomo.good luck
John in IN
03-17-2004 17:42:32
 Re: Re: Bromegrass Rate in reply to jackel,ind, 03-16-2004 21:15:32
I am in the Peru area.
