Front end loader pump
RL
03-16-2004 16:21:54
I just inherited a ford 8n I was told it was a 1952 but if I'm correct and the serial numbers are 312050 then its a 1950. My problem is this, the pump is located on the pto, which makes it a hassel to operate. What do I need and where can I get the stuff to mount it on the front so it will be live full time. Thanks
old
03-16-2004 18:18:51
 Re: Front end loader pump in reply to RL, 03-16-2004 16:21:54
They make a shaft/adpator for that most tractor dealers should have them, it bolts right on to the crank pulley and you mount the pump up front. Works real well I have an 8N and an 801 set up that way
RL
03-17-2004 15:20:41
 Re: Re: Front end loader pump in reply to old, 03-16-2004 18:18:51
Thanks alot "old" I will be making a phone call real soon.
