Replacing Wood bearings/bushings
Doug D
03-16-2004 08:13:29
I'm rebuilding a 10'disk that had Wood bearings, 3" OD with 2" ID. I read where UHMW (ultra high molecular weight) Polyethylene might be a good replacement for wood bearings. Then when looking through the McMaster-Carr catalog I found "Oil-Impregnated Cast Nylon".
The Nylon has good tensile strength, good impact strength, and a 450F melting point, for indoor or outdoor use.
The Polyethelene has poor tensile strength, excellent Impact strength, and a 275F melting point, for indoor use.
The neat part is, these materials can be purchased in the exact tube size that I need. Has anyone used these or similar materials for replacing wood bearings with good results?????
riverbend
03-17-2004 15:33:38
 Re: Replacing Wood bearings/bushings in reply to Doug D, 03-16-2004 08:13:29
I guess you'll just have to try a wood, a polyethelene, and a nylon bushing and let us know how they work out. Anything would beat making a wooden replacement on a tablesaw.
Does either material have a spec for something like cold creep ? Meaning that the bushings are under a lot of pressure and you wouldn't want them to squish out of the box.
Be sure to post the results if you do try it.
