Front end loader
Mark
03-15-2004 12:21:51
I purchased a Ford Front end loader (approximately 30 years old) for my Ford 7610. It is very used and rusty but lifts fine. The former owner(s) did not own a grease gun. There are 10 joints that have lots of wear. What is a practical way take up some of the wear. I suppose a good machinist could drill out all the holes and refit with oversized pins, but I suspect that would be expensive. Maybe I could simply get them to turn some oversized pins and take up some of the wear?
Ultradog MN
03-15-2004 13:07:46
 Re: Front end loader in reply to Mark, 03-15-2004 12:21:51
I just went through this on my own Ford loader.
Here's what I did: Bought 8 1 1/8" grade 8 bolts cost $42.
Bought a 1 1/8" drill bit 43
Rented a "mag drill" from rental shop 46
Bought 8 5/16" spring or roll pins 3
Bought 8 1" flat washers 8
The magnetic drill was a Milwaukee and it sure made the job easier. You just hit the button and a very strong magnet sticks what is esentially a small drill press onto your work. Sideways, upside down, any old way. No way I could have done all that drilling with just a 1/2" drill motor.
Next I put the bolts into the fresh holes put the flat washers on, and drilled the 5/16" holes for the spring pins. Drove the spring pins in and used a angle grinder with a thin abrasive cut off wheel to cut the extra bolt length off and viola new pins in my loader. I bought the grade 8 bolts extra long so that only the unthreaded part (shoulder) got used.
Had all my ducks in a row - bolts, drill bit, washers and spring pins in hand, mag drill reserved for 8 am Sat.
The whole job took me about 6 hours to do including running twice to rent and return the Mag Drill. At $60+/hr. for the local machine shop to do basically the same thing I figured I saved a bundle.
Worst part about the job was lugging that mag drill around. It was heavy 80? lbs.
Made a world of difference in the loader.
I'm glad I did it. Good luck
Jerry
old
03-15-2004 12:47:23
On things like that I cut out the old pin holes and weld in a piece of pipe the the pins will fit in.
