Drum mower ?????
bob
03-14-2004 19:43:02
They are much cheaper than a disk mower, last longer, simpler, much easier to maintain & repair. So how come almost no one uses them. I've talked to farmers who've cut with them & seen where they have mowed. The pictures show a good job.
Hay Dr.
03-15-2004 16:06:44
 Re: Drum mower ????? in reply to bob, 03-14-2004 19:43:02
The drum mowers fit the large compact and small utility segment of the market. We have sold the PZ style drum mowers since 1982 and have sold thousands of them. Many of those 1982 mowers are running today. Check out the CCM Drum mowers. When you want a 7'-10' cut from a 3 point mower then you will need to move to the disc mower.
bob
03-16-2004 15:21:01
 Re: Re: Drum mower ????? in reply to Hay Dr., 03-15-2004 16:06:44
I think I understand. Is the CCm mower belts & u-joint or all u-joint?
Hay Dr.
03-16-2004 15:27:39
 Re: Re: Re: Drum mower ????? in reply to bob, 03-16-2004 15:21:01
PTO to belts to shaft drive across the top. The CCM has the same system as the PZ (PZAG) drum mower that was patented in 1969.
bob
03-16-2004 21:45:48
 Re: Re: Re: Re: Drum mower ????? in reply to Hay Dr., 03-16-2004 15:27:39
How does that system compare to the Galfre that uses only driveshafts? Is it worth the extra $1200? Up here the Galfre(sp?)(5 1/2 ft.) is $3000 & a turkish-made with belts (5 1/2 ft.) is $1850.
