John Deere trailer plow- pull type with metal whee
Roger Brickey
03-14-2004 18:35:59
I recently got a set of plows. I hooked them to my tractor and plowed a furrow but when I got to the end of the row and wanted to get them to lift up out of the ground they wouldnt work. Does anyone know how they work? There is some sort of trip on the left wheel.
JMS/MN
03-14-2004 19:25:10
 Re: John Deere trailer plow- pull type with metal in reply to Roger Brickey, 03-14-2004 18:35:59
The plow is a power lift, as opposed to a hydraulic lift. When you pull the trip rope, the plow should lift as you move forward. Sometimes the whole assembly just needs a good cleaning of all the accumulated grease that has built up over the years. You can also check for broken springs or other parts when you take it apart.
