old wagon running gear
Tim Shelly
03-14-2004 08:34:08
Ive got an old steel wheeled wagon running gear that needs to have the wheels greased. It has about 1 1/4 size caps on each wheel and on the king pins. Did they make a special grease gun for these or is there a different way to go about these? There are no zerks(guess they werent invented yet). Any help will be appreciated.
Leroy
03-14-2004 14:50:31
 Re: old wagon running gear in reply to Tim Shelly, 03-14-2004 08:34:08
That would be called a grease cup, unscrew the cap, fill both sides with gun grease, screw the cap back on, the tighter the more grease pushed in the bearing, usualy on discs and so on would fill cups in morning, screw down enough to get equivalant of a couple of pumps of grease gun at first then every couple of hours would turn down anouther couple of turns till empty then repeat
