3 point hitch conversion kits?
textrout
03-13-2004 17:23:44
I like my catII 3 pt on my JD 4010, but the inplements I want to use are mostly cat I. My lower lift arms wont go narrow enough for cat I so.... does anyone make a cat I to cat II conversion kit for implements (basically extensions of the right diameters)?
Thanks for the help!
Textrout
Bob
03-14-2004 07:10:21
 Re: 3 point hitch conversion kits? in reply to textrout, 03-13-2004 17:23:44
You really, really need to get a manual..... ....
allyn
03-13-2004 18:16:23
remove sway block, turn 1/4 and reinstall. that will narrow it up for cat. 1. bushing from cat.2 to cat.1 you can buy at a farm store.
textrout
03-14-2004 07:14:29
 Re: Re: 3 point hitch conversion kits? in reply to allyn, 03-13-2004 18:16:23
Thanks for the help! That's what I was thinking too, but two of the bolts holding the sway blocks are sheared off- I'll have drill them out if I can. On a 45 year old tractor, that might be a little work! :-)
(I was kinda looking for a short-cut, but ultimately your solution is the best.) Best regards,
Textrout
