Straw is usually the leftover stems of oats, wheat, or rye. You plant them early in spring (or last fall for the winter versions) and harvest the grain in June/ July. Then you rake & bale the straw residue that came out of the back of the combine. It is difficult to short-circut this process & not get the grain. You can't just leave the grain in, as the mice will go crazy. If you cut the oats before it heads it is very soft & green & shorter, everything would rather eat it than lay on it. You could bleach it out in the sun before baling, but only if you live in a very dry climate. In short, only rarely would it pay or even be possible to raise _just_ straw. So, do you want to get in this deep for 5 acres? You will need tillage, drill (planter), swather (unless in a very dry climate), combine, rake, baler, wagon for grain, wagon for straw. Or there-abouts. Or have neighbors that do some portions for you. Straw is really a byproduct allowing us farmers to add a different crop to our rotation. While the small grain is not as profitable as corn & soybeans (here) selling off the straw makes it possible to cash-flow the crop and break up weed & insect cycles somewhat. If you have livestock that use straw, you must also need hay? It would be more profitable & less machinery to raise that & continue to buy your straw. You could beg or borrow the tools to plant the alfalfa or hay, & only need to own the baling equipment. (And NCHillboy, I'm 2 years older than you guessed.... ;) --->Paul
