vermeer super G vs. super I
jason
03-10-2004 04:48:24
I was wondering what the differences were between the two models.I am looking to put up 200 rolls a year. Thanks
James in NC
03-10-2004 10:07:52
 Re: vermeer super G vs. super I in reply to jason, 03-10-2004 04:48:24
The 504 super I has a double twine tie the G has a single. The pickup reel on the I is not as larger as the G. Meaning the hay does not have to go up as far to get to the bale chamber. The I will pack it tighter if it has the Hyd. density system. The I also has the spilt tailgate design. Both good balers. They operate on the same principles. Drum roller, 2 upper drives and 1 lower drive. Oh yeah the I also as a spiral starting roller were the G has a roller with flaps.
James
David Styles from Austral
03-10-2004 21:23:17
 Re: Re: vermeer super G vs. super I in reply to James in NC, 03-10-2004 10:07:52
Do any of the MF balers have a split tailgate?
Have you ever heard of a MF or PZ baler with multiple rollers in the bottom? A bit like a horizontal NH BR960? They are supposed to be better at starting the roll. They have about three rollers in the bottom with a 7" gap between the front roller and the belts. Is the spiral starter much better than the flapper starter for hay??
James in NC
03-11-2004 12:20:04
 Re: Re: Re: vermeer super G vs. super I in reply to David Styles from Austral, 03-10-2004 21:23:17
Masseys with a split tailgate: 656,646,640,634 all made by Vermeer. Masseys with multiple rollers in the bottom would be 450 and 560 models they are a closed throut. Not familiar with NH and PZ so I can't help there. The spiral roller keeps the hay from wraping and helps to start the bale in damp hay.
James
03-13-2004 06:19:36
 Re: Re: Re: Re: vermeer super G vs. super I in reply to James in NC, 03-11-2004 12:20:04
No the ones I have heard about are definitely open throat design with 3 rollers in the shape of a shallow 'V'. The Idea is that the hay conveys off the pickup, across 3 rollers and then is tossed forward like a wave and falls down on the front roller and begins to roll. I think maybe not on MF/Vermeer - maybe on the german PZ balers where they had to change from the patent so they don't pay royalties to vermeer.
Hay Dr
03-10-2004 07:56:47
Both will do a fine job, but the Super I baler is Newer Technology. The Super I will be the better value in the long run.
