case hitch
richard
03-09-2004 16:17:07
have a 47 case va with a odd setup not a eagle fast hitch or a 3pt, but has a hyd cyl in front that raises and lowers a top hitch and the drawbar has a large steel plate with 1in. pins welded at either end if this setup can be used to use reg 3pt. impliments let me know. any help appriciated
cb
03-11-2004 06:52:30
 Re: case hitch in reply to richard, 03-09-2004 16:17:07
You have a pre eagle hitch Case.
You cannot hook up 3-point equipment with out some changing your hitch or the equipment.
In the old days people used pull type equipment. You can still find pull type plows, pull type bush hogs, pull type disks, etc... around.
There was mounted equipment made like cultivators and plows but that might be a little harder to find.
