Steel or Rubber Rake Tines
Matthew(Mich)
03-09-2004 16:08:20
The NH 256 hay rake I just picked up has the rubber rake tines/teeth. Many need to be replaced and was wondering what is the perferred choice for everyone's rakes. My thought was to replace all of them and the rake should last another 30yrs. Just need to know if I should stay with the rubber or put on the steel type? Haven't been around the hay making long so I'm not stuck on one or the other yet.
Matthew
Bob
03-09-2004 19:33:59
 Re: Steel or Rubber Rake Tines in reply to Matthew(Mich), 03-09-2004 16:08:20
Matthew, why don't you look back as 3 or 4 days ago there was a lengthy discussion on this very subject. As a matter of fact I think it was run pretty much into the ground.
RayP(MI)
03-10-2004 18:49:44
 Re: Re: Steel or Rubber Rake Tines in reply to Bob, 03-09-2004 19:33:59
Basic consensus - if you're going to buy rubber, best to buy NH and not the generics. They don't last.
Unimog
03-09-2004 18:35:16
Most guys like the steel type, but I have good
luck with the rubber ones on my NH 57. If one
gets bent, it's easy to straighten in a vise with
a hammer. I only replace them when the rubber is
breaking away from the metal base. They cost a
little more then the steel ones, but as I said,
they are easy to fix.
