Bearings and wheel for old IH 10 disk tiller.
Old Hickory
03-08-2004 18:28:39
I have an old IH 10 disk tiller. It has IH symbol and what appears to be a model or serial number starting with a P debosed in the frame near the lift wheel. It has a metal lift wheel and heavy metal drag wheel in rear and a spoked wheel that carries a rubber tire on the wheel that rides in the furrow. The rim of the furrow side wheel is rusted out so I am looking for a replacement wheel. Also, the furrow side wheel and rear wheel appear to have had either bearings or boxings that are now gone. Would would appreciate any information about the parts that go in these wheel and axle assemblies.
JMS/MN
03-09-2004 17:37:59
 Re: Bearings and wheel for old IH 10 disk tiller. in reply to Old Hickory, 03-08-2004 18:28:39
Since it's an older machine, the wheels might have had roller bearings in them. If the shaft is not worn down much, that would be the ID of the bearing, measure the casting for the OD.
Old HIckory
03-10-2004 13:44:48
 Re: Re: Bearings and wheel for old IH 10 disk till in reply to JMS/MN, 03-09-2004 17:37:59
JMS/MN, thanks for the advice. I will try the suggestion.
