Recently purchased what I thought was a 4B, 2-14 plow to go along with my '35B. Will be pulling in light ground, about 30% sand, so feel I have plenty of power to make the dirt turn. My questions are these;The beam numbers are 582 and 623. According to the GM plow mania atricles a couple of years ago, a 4B should have 582 and 583 as the beam numbers. doing a little more research, I found no plow with those beam numbers, so do I have a morphodite or did some one break a beam and replace it with one close? Second question; It is missing a front coulter assembly, all that remains is the shaft down from the beam. Does anyone have a parts breakdown so I can ask for the exact numbers? I did some looking on JD Parts and the plow does not even come up on the system. Also, does anyone know of a place to get a replacement assembly? Maybe a good salvage yard? Third question; It has an extra set of coulter like assemblies mounted in front of the share about half the height of the share. Are these some sort of special sod breaker? I was thinking that maybe they were some sort of cutter to make the dirt cover better covering the trash better. Are they a rare attachment?
