Best Fertilizer Attachment for JD 290 Planter
Mark C
03-07-2004 19:21:21
I have 2 JD 290 planters and I am trying to make one good one. One has the split boot type fert. drop and the other has an offset disk opener type. I just wanted your thoughts on which is better, so I'll use the best one. I also would like to know how the valves hooked up on the disk opener setup. Thanks
JMS/MN
03-09-2004 17:05:39
 Re: Best Fertilizer Attachment for JD 290 Planter in reply to Mark C, 03-07-2004 19:21:21
When you're planting in heavy residue, disc openers tend to cut their way through, boot/shoe openers tend to plug. Sometimes one old corn stalk is enough to plug a shoe, then it bulldozes.
Leroy
03-08-2004 18:18:17
The offset disc type was so you could use a higher rate of fertilizer without burning the seed, sorry I cant help you on the other, I have 4 of them setting here to rebuild along with 2 of the 4 row versions, one of each under way
