new holland 273 knotter
scott f
03-07-2004 16:50:04
I just bought a New Holland 273 supersweep. The only problem is one of the knotters is not tying the knot or or hardley at all. The guy I bought it from gave up on it after one hot afternoon and bought a round baler. He said he went over the knotter and could not figure it out. He pointed out a brass ball looking type part in the knotter area that looked to be worn. I don't know what that part is called nor do I know what it is designed to do. This may or may not be the problem so I am open to any suggestions.
mh
03-14-2004 06:17:27
 Re: new holland 273 knotter in reply to scott f, 03-07-2004 16:50:04
Probably to simple but I bought a 273 that wouldn't tie. An older farmer told me that if I switched to 9000 twine instead of the 10000 twine it would work better. Baled the next 400 bales without a break
Steve from New Holland
03-08-2004 04:37:12
Scott, I know you want a simple answer, and believe me, I would like to give one, but I'm sorry, tying troubles are not necessarily easy. The brass ball should not be worn, but I also doubt that it is causing you your trouble. Please describe you problem a little more and I will try to help if possible. Again, I doubt the brass ball is your problem. Steve
scott f
03-08-2004 14:04:24
 Re: Re: new holland 273 knotter in reply to Steve from New Holland, 03-08-2004 04:37:12
I appreciate your reply and will get back in touch with you when I have the machine home next week. At that time I will try the machine out and perhaps figure out the knotter problem or give a better description of what is wrong.Thanks, scott
Kelly C
03-07-2004 17:55:54
third party image
That round ball is for the Knife arm. It should not be worn. Could also be on the bill hook cam.
I would sugest a knotter rebuild. About $100 in parts and I have instructions on my web site when I did the knotters on my NH68. Knotters should be the same.
scott f
03-08-2004 14:11:00
 Re: Re: new holland 273 knotter in reply to Kelly C, 03-07-2004 17:55:54
I would guess a rebuild will be in order. Do you think $100. wil cover it. Do you know of any on-line options for the parts or should I take this to the local NH dealer. Thanks for your info. SF
JMS/MN
03-07-2004 17:31:15
Sounds like the ball on the bill hook- should not have flat spots on it. Best bet is get the operator manual for that model baler- excellent advice with pictures to ID good knots and poor, and how to adjust components.
