NH 68 Twine tension?
Chip S.
03-07-2004 06:16:59
Ok, ok. It's still early, but the first green is starting to poke through, so it's time to start getting the baler ready. Last year I had problems keeping the twine tension consistent, so I guess I'll repair or replace the tensioner plates and spring. Any of you guys ever used a spring scale to measure the how many pounds of pull at which the tensioner should be set for optimal operation?
Thanks.
Steve from New Holland
03-08-2004 04:29:34
 Re: NH 68 Twine tension? in reply to Chip S., 03-07-2004 06:16:59
Sorry Chip, but there is no such test. You simply set them for your own preference. Having said that, a good starting point is leaving about 1/8" clearance at the top edge of the spring, just before you bottom out the 3/8" bolt used to hold the twine tension spring. However, some twine holders need more and some need a little less, but not many need less. Steve
Chip S.
03-08-2004 06:06:43
 Re: Re: NH 68 Twine tension? in reply to Steve from New Holland, 03-08-2004 04:29:34
Thanks, Steve. But if anybody has a fihin' scale handy ;)
Jim in michigan
03-07-2004 07:09:56
My plates are pretty rough,, they are still holding though,, I have never messed with them other then putting a lil oil on them to free them up when I bought the baler,,never had trouble with them since,,I do have a S68 for parts though in case I need them,,,Jim
