bush hog type rotary mower.
Flatlander
03-03-2004 21:18:00
I am getting ready to purchase a 3 pt rotary mower to use with a farmall H. From what I see, I should be able to use a 5' mower ok but would like to go with a 6' if possible. I would only be mowing prairie grass on flat ground. I am planning on using a one way ratcheting clutch. Is a 6' mower going to be to big of a load for an H model farmal?
moonlite
03-05-2004 15:51:51
 Re: bush hog type rotary mower. in reply to Flatlander, 03-03-2004 21:18:00
I pull a 6 ft pull type Woods with a "B" Farmall on lots in town where the grass never gets very tall. also can clip pastures with it. Loads it in second. My "B" has an increased bore sleeve set and is in excellent shape. i have larger tractors but like the "B" because it is easier to haul.
Redwolf
03-04-2004 07:49:17
I have a six foot King Kutter behind my stock Farmall H. I normally cut in third and fourth depending on field conditions. I cut twelve acres, takes me about 8 1/2 to 9 hours total. I installed a Saginaw three point kit. I have had excellent results using the conversion.
