Looking straignt down on the wobble box top, there is a "casting type" cover about 3" in dia held in place with 2 screws...that's where I added the lube. I have the sheet metal snap in cover also, but I ONLY FOUND 1 zerk and had to rotate the shaft to "feel" it. I feel that it is to lube the sickle bar fitting to the wobblebox drive shaft. Then there is another zerk on the back side lubricating the v belt drive shaft/bearings. Looking at the way the thing is built and considering functionality, I'd say that the vertical part of the drive mechanism is supported within the casting with a lower bearing (cone roller I'd bet) and an upper bearing, the outer race being installed in the underside of the 3" cover. I suspect that would be a cone roller also. Now, when I said it had gear lube, that may have been 30 years ago. What I got out of the screwhole was more like black mud. The drive shaft/bearings for my NH rake are set up similar where the lid comes off with the outer race and undoing a nut on the shaft allows the assy to be removed. You might want to look at yours a little closer as a right angle turn in a gear box spells oil to me....I can see greasing bushings, or shaft ball/roller bearings, but not gears. Mark
