Need Help to Identify Old Massey Ferguson Disc.
Mitch
03-02-2004 21:48:32
I recently purchased an old 8' Massey Ferguson disc. All that I am able to make out on the name tag is that it was manufactured by Massey Ferguson Limited in Toronto Canada, and the serial No which is 816 002976. Any info I can obtain would be helpful. Would like to find out the model No. and where I can obtain parts.
Thank you
Mitch
JEM
03-03-2004 16:59:59
 Re: Need Help to Identify Old Massey Ferguson Disc in reply to Mitch, 03-02-2004 21:48:32
Is the disc a 3PTH or pull type ? If it is a 3PTH and has hand levers to adjust the gang angles , it could be a MF25. If it is 3PTH,each gang adjusts individually, angle iron frame, it`s a MF39. Parts are no problem from MF.
Mitch
03-03-2004 23:31:49
 Re: Re: Need Help to Identify Old Massey Ferguson in reply to JEM, 03-03-2004 16:59:59
3PTH with angle iron frame. Each gang is independent adjustment. Looks like it's a MF39.
Thank you for the info
Mitch
