Ford Sickle Mower Expert
Mark
03-02-2004 05:50:16
My turn to ask..... directions are when sitting in the seat and this machine came out after the pitman arm type....has wobble box at end of cutter driven from gearbox/vbelt.
I bought a Ford Sickle mower and have installed in on a early 4000 Ford. 3 questions please:
1. I assume the only real purpose of the 3rd member (besides lifting) is to tilt the cutter bar to parallel to the gnd?
2. On the left side is a 1" curved "hootus" that goes up and across the PTO drive and hooks into the last 1/4 of the right lift arm. Has a chain on it and a straight bar with flip lever for fitting into arm. What does it do and how should it be adjusted?
3. It has a breakaway bar on the right consisting of a big spring (3") and a piston looking thing. I hit an object last year and it broke loose (allowed the cutter to fall back about 1') and I saw what I'd call the piston shaft. There was light rust all inside it. It stayed out and to put it back in place (cutter bar 90 degrees from tractor travel) I had to back up to a stump and push against the cutter bar and it sorta snapped back in place....but it doesn't act like it wants to stay. Could you explain how this is supposed to work.
Thanks and I love this forum..... going and coming. What did we ever do without it?
Thanks in advance for the help I know a bunch of great guys are capable of ..... spring is coming. The Robins came through the place Sunday....it had just rained and the worms were on top....birds had a field day.....thousands of them.....Yesterday they were gone....back home.
Mark
Geo in SD
03-02-2004 08:11:27
 Re: Ford Sickle Mower Expert in reply to Mark, 03-02-2004 05:50:16
What you have is a 515 pitmanless mower. I'll try to answer your questions. No. 1- you are correct. No. 2- That dingus with the curved bar and chain- the chain should have a pin with a spring and a flip lever at the bottom of it. This pin goes into your drawbar against the tension of the spring and the flip lever locks it in the hole. The spring is tapered. You adjust the length of the chain to acheive your cutterbar lift height. There should be a large hole and slot or two for this in that curved bar. Swing the drawbar off to the right side slightly to clear the pto shaft. No. 3-- The safety release is supposed to let the sickleswing back if an object is struck. You should simply be able to back up with the sickle on the ground and reset the release. There may or may not be a grease fitting in it somewhere. In any case it sounds like it could be cleaned up and lubed with something. These are one darn good mower, hope you have good luck with it. I own one myself and love it. Nice and quiet and fast, my god it's fast. I've had it on my 4000 SOS and can mow in 8th gear in anything, clipping pasture, I could probably run in 9th. I can tell you a few more things about this unit, but this is getting lenghty. E-mail me if you have any questions or comments.
Tom
06-03-2004 13:17:39
 Re: Re: Ford Sickle Mower Expert in reply to Geo in SD, 03-02-2004 08:11:27
I think I just bought the same cutter. Can one of you email me a photo?
Also, my mower's curved dingus with the chain on it doesn't have the spring and cross latch. Any chance of a photo?
Glad to hear that it is a good mower. I'm guessing that manuals and parts are still available at New Holland (800) 635-4913.
Mark
03-02-2004 09:36:23
Thanks Geo very much for your prompt and educational response.
In #2 my spring is missing which I will replace and in #3 I will lube the piston. I assume friction is all that holds it in place and to reset you just go against it....I must have too much.
The machine is definitely quiet but yours must really be in good shape to go in 8th gear. I had a 4000 SOS and I know how fast they are.
The part I dislike is mounting. I mount it once and it stays on the tractor all year. Use other tractors for other jobs.
Thanks again,
Mark
Geo in SD
03-02-2004 10:37:13
 Re: Re: Re: Ford Sickle Mower Expert in reply to Mark, 03-02-2004 09:36:23
Mark:
In no.3 there might be a latch that looks like a toggle on the front part of the spring assembly. That is what actually holds the breakaway until the sicklebar hits something. Don't forget to remove the cap on the wobblebox and lube the fittings inside and at the bottom.
Mark
03-02-2004 11:58:38
 Re: Re: Re: Re: Ford Sickle Mower Expert in reply to Geo in SD, 03-02-2004 10:37:13
Now that you mention it I think I do recall seeing a latch of sorts that pops up to allow the piston to move back. I will investigate this afternoon when I get home.
Thanks,
Again.
Like I said a couple of days ago. You're not alone anymore...someone is out there ready and willing to help you.....isn't it grand.
Mark
