NH 256 Rake U-joint replacing.
Matthew(Mich)
03-02-2004 04:31:14
The universal joint on the side opposite of the gear box needs replacing. Just wondering how it come's apart. Are there snap rings holding it in on the inside of the caps? The one's I've seen had the snap rings on the outside of the caps and you remove the rings and the u-joint comes out. Anyone change a universal joint on a NH hay rake?
Matthew
Gary in TX
03-05-2004 22:21:54
 Re: NH 256 Rake U-joint replacing. in reply to Matthew(Mich), 03-02-2004 04:31:14
Matthew,
Are you talking about the u-joints on the driveshaft between the wheels? If so when I tried to get them for my 56 rake one time as I recall you couldn't get the u-joints separately. I had to buy the whole yokes and all adn was really not a bad deal. I'll be posting a pic of my rakes when I'm done with them, they are getting a full paint job and one is getting full tine bar bearing change. Looking good so far!
rjones
07-11-2005 19:56:57
 Re: Re: NH 256 Rake U-joint replacing. in reply to Gary in TX, 03-05-2004 22:21:54
Do you know anything about the gear box for 256 NH rake? I need help and cannot locate an illustration. Thanks
Steve from New Holland
03-03-2004 04:26:24
Matthew, the snap rings are internal. If you do replace it while the yokes are still on the rake, let me know. I would like to congratulate anyone good enough to replace ujoints without removing them from the machine first. It is possible, but it takes a real man. I guess I am not a real man. Have fun, Steve
