MF 135
Not Sure
02-29-2004 19:17:27
quick question for ya fellas... i have a hesston 1071 haybine, 7 foot mower... whats yer guys opinion on running this with a massey ferguson 135 gas. thanks in advance. i know the machine can run it but do you think its wise...as far as enough hp to run it efficiently without overworkin the tractor
wolfy
03-01-2004 17:10:48
 Re: MF 135 in reply to Not Sure, 02-29-2004 19:17:27
If it's a 3-cyl Perkins gas, it has 37 hp. (the 4-cyl continental earlier models had 34 hp). Hills & weight would be more of a concern than hp.
Jerry D in NC
03-01-2004 09:04:48
I pull a 7' JD 1207 MoCo that I imagine is very comparable to the NH with a Ford 2000 as fast as I want to sit in the seat in most conditions and in heavy hay I may have to slow down but that is more to accomodate the MoCo than the tractor. 2000 and the 135 are very comparable in size and HP. I think I could pull a 9' under most conditions just fine but the deal came up on a 7' before a 9'
Gary in TX
02-29-2004 21:21:37
I've run a 9' New HOlland 469 and a 488 with my 135 gas and never had any problems at all that I can recall. HP ratings for the 469 and 488 required a min of 35hp. If your going to run a 7' machine with it, I would say it would probably walk away with it.
Bob
02-29-2004 20:36:47
Check your Hesston manual. It will give you the horse power requirements for this machine. Check your tractor specifications for the correct hp of your unit. Good luck..... ...
