7' vs. 9' haybines
Josh
02-27-2004 15:37:06
I cut about 60 acres of hay in SE PA. I am in need of a new haybine, and found a really nice 7'NH 467. Before i have always had 9'. My rake is 9' my tedder is 9' and a 9' swath is a nice amount for the baler to handle. Going to 7' seems like it will mess up the whole operation. How have you guys with 7' mowers done this? Will this be a big problem, or will it work out ok? Thanks for the advice.
Dick
03-05-2004 16:31:45
 Re: 7' vs. 9' haybines in reply to Josh, 02-27-2004 15:37:06
Hi Josh: I would be interested in if you got the 467 and how you like it. Thanks Dick
Kelly C
02-28-2004 16:18:37
I just towed my 9' 469 home and you have to drive down the center of the road to keep from tagging mail boxes all the way.
Phil Munson
02-28-2004 11:50:03
Advantages of the 7' include a swath without a tractor wheel track in it; for faster drying. Obviously, easier to move through narrow gates and on the public highways. Also, a lesser tractor can operate the 7'.
I would be tempted to increase the fertility management to get more hay in the 7' swath. If that is not an option use the rake to throw two or three swaths together for the baler; and operate the press at a reduced ground speed.
Where I live, in upstate NY, the problem is not getting the hay on the ground, but with our fickle weather, getting it cured and pressed. A fast drying swath can be worth a bunch around here.
Mark
02-29-2004 09:41:28
 Re: Re: 7' vs. 9' haybines in reply to Phil Munson, 02-28-2004 11:50:03
Have you considered a rotary tedder? I just recently noticed them being used around here....right after cutting come back with it and it scatters the hay for quick cure and subsequent color preservation.....horse folks in Texas want their coastal green. I noticed ASC sells them for $1 to $3k depending on how big.
I am starting out in the hay business and want to use a sickle mower to do my grass type hay. Problem is, my place is odd shapes and I wind up with clumps that do not cure.....will set a barn on fire if bailed as is. So I either use a swather that wind rows and eliminates the lumps or a rotary cutter which is ok but some people want to see the stalks. By the way, the rotary cutter (bush hog thing) is much faster than the chook.a.chook.a.chook.a.
In writing this to you I dug out the ASC catalog and see this one in here for $1000.....looking better all the time....but it does mean one more trip across the field.....but what I have seen for results are beautiful bales.
I too have the weather problem in the spring and the weather man never knows about that "little shower" that pops up.
Mark
wolfy
02-27-2004 20:56:15
Just think of the extra miles(and time for such) you'll make going around the fields not only with mower, but with tedder, rake, baler.
Tim(nj)
02-27-2004 20:14:32
I have a JD 1209 9' that is now surplus to my needs. I'm in Pittstown, NJ. E-mail me if interested.
Rick
02-27-2004 18:55:01
Josh; I have a very nice JD 1460 disc mow/conditioner for sale if that would help. I am just going to 12ft or larger machine.
Bill B
02-27-2004 17:50:15
Hi, I have a 7 and 9 ft JD MoCo. I would never go back to a 7 ft. It's hard to pick up 2 7 ft windrows with a 9 ft tedder. Now if the 7 ft is a diskbine you may beable to make up the lost time with the increase speed the mower runs at. Bill
Nebraska Cowman
02-27-2004 17:30:30
No. I don't think you would be happy with it. It's going to cut 20% slower.
