Taking steel wheels off of 2 bottom plow
Justin
02-24-2004 10:34:24
Can anyone tell me how to take the steel wheels off of my 2 bottom plow? There is a small bolt on the outside of the wheel, and there are two bolts that are attached to some sort of bracket on the axle. Any help is greatly appreciated.
Thanks
Bill Smith
02-25-2004 10:46:08
 Re: Taking steel wheels off of 2 bottom plow in reply to Justin, 02-24-2004 10:34:24
Little confused what you are talking about. If it is a pull type plow and taking wheel's off, and the hud/wheel is all one peice you should be able to remove wheel by taking it apart at the hub. If you are talking about the sod cutting wheel's/discs, which are an extra attachment and cut the sod ahead of the plow, you should be able to remove them by unbolting at the frame (take the arm and all off). I am just not real clear what you are getting at and trying to do (on what kind of plow).
