how much oil in bushhog
tom
02-24-2004 04:04:33
I have a bushhog that i just got and was wondering if it should be full to the top of the hole or leave some room in it my other bushhog hole is at a slant and the other is at the top thanks Tom
RickB
02-24-2004 15:15:59
 Re: how much oil in bushhog in reply to tom, 02-24-2004 04:04:33
Without better info the rule of thumb is to fill a gearbox to halfway up the horizontal shaft. Use a piece of wire or similar device as a dipstick if needed.
Bill Smith
02-24-2004 13:40:59
Generally speaking, gear boxes ussually have a plug at the top. This is where you put oil in at. They ussually have another plug half way down on the side. Take it out and fill to that level. Gear boxes generally are suppose to be filled in the neighborhood of half full. Some boxes have drain plugs at the bottom, and some don't. Some boxes just have a plug on the side and not at the top. If so, you might have to use a rubber hose or squirt bottle to add the fluid and that same plug hole is where it is suppose to be filled to.
Mark
02-24-2004 06:10:05
Fill hole on top usually 3/8 pipe. On the side of the housing is a 1/4 plug somewhere around half way up. This is your exhause port. Open it and fill til she runs out.
Mark
