Rock Picker suggestions / experiences
Jon
02-23-2004 10:34:29
Hello all.. I am looking for opinions on rock pickers. My father-in-law is looking for one to get the rocks out of about 100 acres he is planting. He has looked at the ones you pull behind that tractor, 3 rake wheel, 2.5 cubic ft bucket. Literature says they go down about 8- 12 inches. They get out rocks down to 2 inches. I am a bit scepticle. If they don't let anything smaller than 2" through, I would think you would end up with a bucket full of dirt.
We are in southern Indiana, It's not real rocky, but he has some bottom ground where the creek as got out into his fields and spread some rock out over time.
Anyone use one of these?
Thanks for any comments.
Jon
Hugh MacKay
02-24-2004 02:40:54
 Re: Rock Picker suggestions / experiences in reply to Jon, 02-23-2004 10:34:29
Jon: None of these rock pickers work by going into the soil more than an inch or two. They are designed to work in conjunction with spring tooth culticators that lay most of the rocks on the surface. What will put soil in with the rocks is trying to operate these machines when ground is wet.
I used to do custom rock picking, and machines like Hay Dr posted photo on work well. Some situations the rock rake will work better. I have indeed picked up windrows from a rake with one of my pickers. If you have very scattered rocks the very best machine I've found are skid steer loaders with rock fork. The beauty of the skidsteer is you can see tip of the fork, much better than with a tractor. They also now have a hydraulic sweeping device for skid steers that pull the rocks into the fork.
If I were tackling your project today as you describe it I would go with the rock rake and rock fork for gathering up the windrows. If indeed your rock problem is much worse than it sounds, Hay Dr's picker is the answer. Just my opinion, no one type of machine is best for all situations. I used 3 pickers each one different, 2 rakes and 2 skid loaders.
Sid
02-23-2004 20:10:55
I have seen a couple of them in use, yes they get small rocks without a bucket full od dirt.
Jay
02-23-2004 15:31:54
Check out the Haybuster 3106 Rock-Eze. It does an incredible job of picking rocks, but on 100 acres, the cost per rock may get expensive.
Hay Dr
02-23-2004 18:20:57
 Re: Re: Rock Picker suggestions / experiences in reply to Jay, 02-23-2004 15:31:54
third party image
That's a great rock picker we leased those out for farmers for 15 years but now we can not pull them on the highway so we rent out the Vermeer rock picker because we can legally pull it down the road.
