hookup
Mike Wilbins
02-22-2004 15:58:47
I have a 2600 Ford diesel with a round PTO shaft and want to hook up an older Deere rototiller (48"?) that has a square shaft coming off the u-joint on the gear box. The distance between them is approx 12-18". Any trick? you can also use my home [email protected]. Thanks.
Tim(nj)
02-22-2004 16:39:28
 Re: hookup in reply to Mike Wilbins, 02-22-2004 15:58:47
Your tiller is missing half of its telescoping PTO shaft. You need the other half that has the corresponding slip tube, U-joint, and 6-spline snap lock end.
