Bought JD 310 disk Oats Help?
Anthony
02-22-2004 15:24:56
Have a small ranch in Texas bought this jd 310 disk looks good was wanting to plant some oats for my cows on 40 arkers next winter someone said all I need is a grain drill. Never planted anthing before??The older man told me to disk the land 3 or 4 times being my land has'nt be worked for 50 years. Then he said buy a drill & use oats for my cattle more protein.Then after the seeds out disk it litely to cover it up,then hope for rain. Thats how to plant Oats????Do I need anything else I have a JD 4230 tractor.
Jim B
02-23-2004 04:35:12
 Re: Bought JD 310 disk Oats Help? in reply to Anthony , 02-22-2004 15:24:56
Anthony,I live 30 miles S of Ft.Worth and have been planting oats and wheat for several years for cattle to graze.I tandem disk two or thre times,sling out fertilizer,then sling out wheat and oats,plow in with field cultivator.NO drill,works great,faster than drill,no sacks to tote and get rid of.If weather permits I try to have it in ground by Sept. 15 but did have to spray for the pesky armyworms last fall.I don't try to till very deep because if it rains much in fall and winter cattle will bog to their bellies as I never pull them off of the wheat.Jim B
Flurette Farm
02-22-2004 18:18:36
Anthony, I'm praying for your cattle..... ..... Good luck
John A
02-22-2004 17:05:47
Anthony, A good 13 shank cheisel plow would be helpful. Chiesel 2 times first, the disc 2 or 3 times. Start as soon as possible, for spring rains will help dissolve the big clods. And you will have the whole summer to get this 40 acre field in shape for fall.
Set the drill at about 100 to 120 lbs/ acre since you are going to graze it. The trick to getting in Oats or Wheat in Central Texas is early, but not to early for the Army-worms will get into it and you have to spend a small fortune to kill the army-worms. In the Central Texas region October 1st is a good planting time.
It also gets up enough to attract the deer for deer season too. Hollar if I can of help!
Later,
John A.
