Advice needed to build tandem rake hitch
Ron
02-21-2004 16:01:16
I have a set of 256 NH rakes and I want to build the hitch to pull them in tandem. I've seen several different types, but what I want to build is the kind that simply hooks one behind the other via a dolly on the back one hooked to front one. What I need is some idea of the measurements of the components to make this. I've got everything I need to do the work, so building it will be a lot cheaper than buying one. Besides, I like doing things that I can on my own. Any help or advice would be very much appreciated.
kyhayman
02-21-2004 16:53:12
 Re: Advice needed to build tandem rake hitch in reply to Ron, 02-21-2004 16:01:16
I've got a picture of one I built under NH 56 Photo 1 on about page 3 of the 'Impliment Photos'. I made it out of 7' of 4" square dubing and 6' of 3"square tubing, Used 4" C channel to attach to the frame. When full extended I added a light chain with 1/4" bolts to the end of the hitch to support yet to allow it to chear if necessary. Used a pc of 4" by 1/4" flat for the tongue.
Regards,
David
