Hillside tillage
Tomas
02-17-2004 12:17:08
Keep me out of trouble and in the 21st century. I have a 15 acre, steep (30 degrees slope) meadow that I want to kill and replant in better forage. I have a plow, disc and tiller, but if I work up the sloped areas on this field, I'm afraid any remaining topsoil will be in the creek before the clover gets established. Will it work to kill with Roundup and overseed after burn down, or will I be wasting seed and time. Any suggestions will be appreciated.
Sid
02-17-2004 17:53:38
 Re: Hillside tillage in reply to Tomas, 02-17-2004 12:17:08
I agree with bob about frost seeding if you want clover. I get better results when cattle are in the field that I have just seeded. I have seen some mix clover seed in with their mineral and let cattle scatter it for them.
Aaron SEIA
02-17-2004 13:16:53
I'd use the Roundup to kill it off. Will work perfect, just be sure to use enough, some of those meadow grasses can be pretty tough. Then, go to your local county soil agency and see if they have a no-till seeder that you can rent, or check with your local farmers, might find someone to do it. I wouldn't lay the seed on top, but if you can get it drilled in, should work fine.
Aaron SEIA
Tomas
02-17-2004 14:00:17
 Re: Re: Hillside tillage in reply to Aaron SEIA, 02-17-2004 13:16:53
Aaron, I've struck out finding a drill I can use, but I'll keep trying. Many thanks, Tom
old
02-17-2004 14:04:25
 Re: Re: Re: Hillside tillage in reply to Tomas, 02-17-2004 14:00:17
If you can't find a drill light discing will also work just not as good.
bob
02-17-2004 15:51:57
 Re: Re: Re: Re: Hillside tillage in reply to old, 02-17-2004 14:04:25
now is the time to frost seed in the East central states.
del
02-18-2004 06:40:14
 Re: Re: Re: Re: Re: Hillside tillage in reply to bob, 02-17-2004 15:51:57
Old timers always said to get the frostseeding done before the first of March here in southern Ohio.
Tomas
02-18-2004 04:36:17
Bob, we still have about a foot of snow on my place here in the mountains of WV.I'm planning of frost seeding in about two weeks.
