Sticky snow plow blade
Matthew G. von
11-12-1998 08:55:45
Using a 1925 horsedrawn Adams Leaning Wheel Grader (Model 1C) to clear the roads of snow. It's steel-wheeled and the blade and wheels tend to get some snow, ice and/or dirt buildup. Tried spraying some WD-40; worked for a short while. Looking for a longer-lasting solution - high-gloss paint, non-stick cooking spray, some kind of Teflon application? Thanks for any advice - hate to be carrying the wide-blade putty knife all the time!
John
11-13-1998 05:49:56
 Re: Sticky snow plow blade in reply to Matthew G. von Hobe, 11-12-1998 08:55:45
: Using a 1925 horsedrawn Adams Leaning Wheel Grader (Model 1C) to clear the roads of snow. It's steel-wheeled and the blade and wheels tend to get some snow, ice and/or dirt buildup. Tried spraying some WD-40; worked for a short while. Looking for a longer-lasting solution - high-gloss paint, non-stick cooking spray, some kind of Teflon application? Thanks for any advice - hate to be carrying the wide-blade putty knife all the time!
We use ski wax. Works great but we only use it on the blade since it's a 3 pt. outfit but I don't see why it wouldn't work on steel wheels too. I don't know what area you are in but you can normally get it at most sporting goods stores.
Matthew von Hobe
11-13-1998 10:47:54
 Re: Re: Sticky snow plow blade in reply to John, 11-13-1998 05:49:56
Thanks John - yep, I'm in the south-central mountains of Colorado. Should be able to scare up some ski wax without TOO much trouble! :)
Hawgee
11-12-1998 20:19:04
Use the cheapest non-stick cooking spray there is. I get "Golden Harvest" from Costco and works great. Keeps the snow from building under the horses shoes and foot also.
Joe Fabregas
11-12-1998 16:18:44
The slip-plate is neat stuff, but you have severe conditions and it probably won't hold up too well, especially on the wheels. You'd probably have to reapply after every use. Some guys use PAM on their snow blowers and blades. Be interesting to hear how your experiment goes. Good Luck! Joe Fabregas [email protected]
Tim(nj)
11-12-1998 10:23:23
Paint it with Slip-Plate graphite coating.
You can get it at many farm supply stores or order it.
snowman
11-12-1998 10:23:05
Might try some slip plate a graphite type of paint
