Hesston PT-10 Reel Carryover
Mark in OK
02-11-2004 00:31:22
I bought a PT-10 last hay season. I use it to cut blue stem hay only. The sickle does a good job of cutting, the problem is the grass won't feed through the rollers. So when there gets to be a build up of grass in front of the rollers (if it doesn"t slug through) it will stall the reel clutch or carry grass over the top of reel. I have a manual on the machine and have made every adjustment i know of to correct the problem with no progress. I have adjusted the lean bar height, adjusted reel height/tine timing, set the spacing and tension on the rollers in multiple combinations with no real change. I'm starting to wonder if the top roller (RUBBER) is wore out not letting it grip the grass and pulling it through at an even pace. Any ideas, Thank You, MARK
Jim in michigan
02-13-2004 07:04:23
 Re: Hesston PT-10 Reel Carryover in reply to Mark in OK, 02-11-2004 00:31:22
your cables maybe to tight, try loosening them off a bit....Jim
Gary
02-11-2004 15:49:56
Mark, sorry I can't help you with your cutter and hope you get it fixed, the reason I'm e-mailing you is I'm needing a manual for the PT-10 I got a few weeks ago. If you feel like making a copy of your manual e-mail me back on your price. Thanks Gary
Gary
02-11-2004 16:18:01
 Re: Re: Hesston PT-10 Reel Carryover in reply to Gary, 02-11-2004 15:49:56
I would be glad to send you a XEROX COPY of a owners manual for the Hesston PT-10. On price how about five dollars for a complete copy plus the cost of postage of priority mail service. If you are interested send me your mailing address and you can return payment when you get the manual. Or you can call and we will set things up. Mark (918)467-3414
Gary
02-12-2004 17:29:24
 Re: Re: Re: Hesston PT-10 Reel Carryover in reply to Gary, 02-11-2004 16:18:01
That will work for me. Gary Mills 405 W.11th. St. Caruthersville, MO. 63830
Tim IN
02-11-2004 08:31:24
I have had success by adjusting the position of the reel, by moving it more up and closer to the rollers in alfalfa. I think the manual suggests a more down position for the reel in tangled, downed crops, but it seemed that it pulled the reel too far away from the conditioner rollers and I had feeding problems. I also have the pitch of the teeth set out so that the teeth come about one inch away from the rubber roll at its closest point. It sounds that you have already tried different reel and tine adjustments, however. I believe that a different sprocket could be used to affect the speed of the reel on its chain drive possibly.
Mark in OK
02-11-2004 17:14:31
 Re: Re: Hesston PT-10 Reel Carryover in reply to Tim IN, 02-11-2004 08:31:24
Tim, I have made lots of ajustment on the reel up and down along with the pitch on the teeth. I remember the manual calling for that 1/2 inch clearance and if you get the reel too high the teeth will catch on the top of the cowling. However you touched on a idea on reel speed. First of all the manual calls for two sprockets for reel speed and i have the 10 tooth on the machine which is for the slower reel speed. However in my meadow there is a long downward slope and the machine works perfect as long as were going down hill. PTO rpm (reel speed) or ground speed makes some difference. Slower is better. My next possible fix was to change the angle of the sickle head/ rollers. It's now set at 0 degree angle and the manual tells how to set it up at a downward angle. I feel this may help since it works better when going down hill or is the angle of the sickle that big of deal. Thanks Mark
Fern(Mi)
02-11-2004 04:41:35
I'm operating older 500 & 1400. So they're simular. I'm wondering if the reel is taking the cut away from the sickle bar soon and evenly enough to avoid the crop's bunching up into the auger?
Mark in OK
02-11-2004 17:42:11
 Re: Re: Hesston PT-10 Reel Carryover in reply to Fern(Mi), 02-11-2004 04:41:35
Fern, I'm running the 10 tooth sprocket for reel speed which is the smallest available i think. However heavey grass and slow RPM speed with a faster ground speed worked best and this is how i got by last year. With lots of stops and unjamming the reel with bunching grass. Sometimes to the point the sickle would sled over uncut grass when bunching got real bad.
bryan g in mo
02-11-2004 04:31:05
have you made the adj to the reel for when it releases the grass, there is a adj for when the teeth of the reel say dumps the grass in front of the rollers. I have a hesston 1071 ,just a little newer than yours, I have also noticed that if the hay is really dry I'll get a carry over on the reel ,but it feeds through on the time around ,and that doesn't happen very often.hope this helps
Mark in OK
02-11-2004 18:07:06
 Re: Re: Hesston PT-10 Reel Carryover in reply to bryan g in mo, 02-11-2004 04:31:05
Bryan, This is the adjustment i have made the most since it is easy to make in the field. I found a point that the (teeth timing) worked the best but still had lots of bunching and carryover problems. Thanks, Mark
