Rotating / Spinning Box Blade
RHKirk
02-06-2004 09:18:44
Have any of you guys ever seen a box blade that rotates for different uses? My father-in-law has one and I would love to find one too. He says it is probably 40 years old. You can use it like a normal box, rotate or flip it 90 degrees to put the teeth down and then another 90 degrees to kind of run it backwards. Using it Backwards does a real nice job of smoothing without digging much out. If anybody knows what these are called or what brands were made I would really like to know.
Smitty
02-07-2004 08:33:00
 Re: Rotating / Spinning Box Blade in reply to RHKirk, 02-06-2004 09:18:44
Sounds to me like a tumble bug. Is your father in law's hitched to drawbar? Does it have a trip lever to be pulled from tractor seat to allow the barrel or box to rotate to the next position? My father had one, he dug a small pond for the cows to drink from, using just that tumble-bug.
On the other hand, several current manufacturors make a rollover box blade, that is regular 3 Point hitch.
