Disc Whipping- the rest of the story
pete
02-04-2004 17:15:16
Thanks to all of you for the tip, will definitely try the come-along idea, think it hold's promise.
To defend myself though I must say it get's a little complicated.
I'm a small cattle rancher in N. Tex. I have several properties separated by a total of 27 miles. Half of which is US 287 south of Wichita Falls. I generally have to run this route twice a year. I nowadays pull this disc with a JD 4840 with duals.(Got a steal at an auction) Buying a trailer big enough for this rig is cost prohibitive. Also running down the highway with it ain't much fun, I spend a large part of time in the grass account the shoulder isn't wide enough for the whole rig. Need to run as fast as the tractor will go to reduce time in the fast lane. (about 24 mph). There's a lot of folks out there that will come flying up behind you at 70+ even though I have signs waving and lites a flashing. Tried pulling the disc with the p/u once, got scary. Since I usually plow with a chisel in tandem with the disc I tried it with them both on, really got scary. Guess I ought to buy some new iron, but got more iron now than silver.
Thanks again pete
Ps: Lite rain, 32 degrees----- - don't cha wish you were here !!!!! !!!
Joe Evans
02-05-2004 11:35:52
 Re: Disc Whipping- the rest of the story in reply to pete, 02-04-2004 17:15:16
I'm reading these posts with great interest. I recently bought a 10' Oliver wheel disk and towed it 9 miles to the house. Had to go no more than about 12 MPH and then shotgun a bottle of Maalox when finally arriving at the house. That dang thing see-sawed all over the place. Will keep the come-along suggestion filed away.
Kent
02-05-2004 08:29:00
Pete, I have always had good luck by taking a small come-a-long and hooking one end to the tongue at the hitch pin and the other end out to one side or the other and winch it in a bit to tighten it up and would tow at 40 to 50mph with no wagoning and of course slowed for dips and bumps, etc. Good Luck, Kent
Hugh MacKay
02-04-2004 18:42:14
Pete: What make is the disk? How large, cutting width? If your using 4840 the disk must be much larger than I earlier anticipated. Usually big disks aren't that bad on whipping. In my years of farming, early on I had 8 and 12 disks that were real bad on whipping. I later had a 20' Bushhog, it towed like a Cadilac. I know several of my neighbors had 16' and larger disks, other makes, and they all towed great on road. I often moved mine with pickup, but at speeds not any faster than tractor. And yes I guess likely I did exceed 17 mph but no more than 25 mph. I was always more concerned about bumps and not being able to stop with pickup.
A neighbor of mine had the transport lock break in the middle of village, on a rough RR crossing. As the hydraulic cylinder was with tractor on another implement, down came the disk on the asphalt. 16'non folding disk and he was blocking both lanes, of two lane road, plus the pickup wouldn't pull it off roadway. A guy with a forklift came to his rescue. Had another guy tell me about bending disk suspension on one side, from hitting a bump on road, and they could never keep it straight after that. When disking it would always cut deeper on one side.
wh
02-04-2004 17:47:49
again , i would say to check for any "lost motion" in the tonge, axel, wheel bearings, and any thing else that can move when pulling it. it should run straight. i know our tufline disc do. they have hubs/bearings just like a regular trailer axel.
