JD Flexiplanters for small seed
riverbend
02-04-2004 08:26:48
I am using JD 70 Flexiplanters for small seeded greens like arugula and mustards. They run about 200,000 - 240,000 seeds per pound. Mostly the planters work great, the trouble is that the seed works its way out between the plate and the hopper bottom.
Does anyone have an idea on how to narrow that gap ? I am using the plastic Lincoln Ag plates.
Tim(nj)
02-04-2004 13:16:32
 Re: JD Flexiplanters for small seed in reply to riverbend, 02-04-2004 08:26:48
I'd try cutting some slippery plastic of the right thickness to put under the plate. There were rings available from Deere for my 494-A planter to put under the plate for small seed like millet.
riverbend
02-04-2004 15:44:14
 Re: Re: JD Flexiplanters for small seed in reply to Tim(nj), 02-04-2004 13:16:32
Good idea, thanks.
My manual lists several false rings and floor plates, but does not show a picture. Do you recall what they were called or still have the JD part number ? I would say that the 70 hoppers would go right on a 494.
Thanks again for your help
Greg
