What blade do you use? And some blade concerns.
Brian
08-07-1998 09:14:22
I use an Armor Implement Co. 6 ft. heavy duty rear blade. This is a heavy blade, and the lift seems to be choppy when lifting it. (Interestingly, the lift is smoother with lower RPM's.) I was wondering if anyone thinks this blade is too heavy. Also, I'd be interested in knowing what rear blades you guys use. Thanks,
BS
Terry
08-10-1998 14:18:05
 Re: What blade do you use? And some blade concerns. in reply to Brian, 08-07-1998 09:14:22
: I use an Armor Implement Co. 6 ft. heavy duty rear blade. This is a heavy blade, and the lift seems to be choppy when lifting it. (Interestingly, the lift is smoother with lower RPM's.) I was wondering if anyone thinks this blade is too heavy. Also, I'd be interested in knowing what rear blades you guys use. : Thanks,
: BS
We use a Modern Implement Co. Heavy Duty 6' blade, also have a HI-CO bush hog that's real heavy. Give's the 2N a work out but never stops her.
