Silo Loaders and Unloaders
Bob
02-01-2004 14:22:40
We bought our farm about a year ago tha was a working dairy farm about 5 yrs ago. We have horses, with the stalls set up in the barn, using dried wood shavings (pine shavings) for bedding. I can buy them in bulk for dirt cheap in this area.
I was wondering if I could use a silo loader to blow them in, then use the unloader (in good working order) as needed.
My thought is the shavings are much lighter than silage, so they should blow in and out pretty good. Any other things I am not thinking of?
Thanks
Warren
02-02-2004 15:33:41
 Re: Silo Loaders and Unloaders in reply to Bob, 02-01-2004 14:22:40
Bob,
As you can see, putting the shavings in the silo may not be your best idea. Why not look at constructing a large bin in one of the hay mow bays. You could use a 40' elevator to get the shavings in the mow. If you construct some type of trap door or hatch at the bottom of the bin, it would be easy enough to drop it down into the barn whenever you need it. If you hang a length of chain to go through the hatch, you could help prevent the inevitible bridging of the shavings - just open the hatch and give the chain a twirl and down comes your shavings. The barn would keep it dry and the elevator can also be used for the hay that you will need for the horses.
Bob
02-02-2004 17:24:25
 Re: Re: Silo Loaders and Unloaders in reply to Warren, 02-02-2004 15:33:41
Warren,
GREAT idea. I now have a (another) winter project.
Thanks to all who kept me from burning down my barn and the sugestions.
Bob
Dale
02-02-2004 10:26:15
On top of the fire risk, it depends on the height of the silo. If it's only 20 or 30 feet it might work all right, but shavings are pretty light and the lighter the material the harder it is to blow a long distance. I doubt you get get shavings to blow into a 40 or 50 foot silo, they'd just plug the pipe.
Tim(nj)
02-01-2004 14:31:08
If it's a pack-drive unloader (runs over the top of the silage and works its way down the silo) it won't work in shavings. It'll bury itself.
Bob
02-01-2004 15:44:42
 Re: Re: Silo Loaders and Unloaders in reply to Tim(nj), 02-01-2004 14:31:08
I am not sure exactly what kind it is, but was looking at it, and thought you lowered it via the attached cable and winch to lower as needed. Am I wrong?
Thanks for your help!!
Bob
02-01-2004 19:05:39
 Re: Re: Re: Silo Loaders and Unloaders in reply to Bob, 02-01-2004 15:44:42
And know you know why I ask such questions. Thanks for steering me around a potential disaster! I will work on Plan B, whatever that may end up being.
Tim(nj)
02-01-2004 17:20:56
Yes that's how it works. But in loose materials, the rotor might just dig itself in and not move. Another problem is the electric motor. If it isn't totally-enclosed dust and spark-proof, you have a potential for massive explosion with all that fine particle wood dust in the silo.
JB
02-01-2004 16:49:33
Hi, becareful using a forage blower to blow dry material. I heard about a chicken farmer that was using one to blow straw bedding into his chicken barn and there was either a stone or a piece of metal in the straw. When the stone or metal hit the metal paddle of the forage blower it caused a spark and the air from the blower fanned the spark and bedding caught on fire. Burned the whole barn down.
JB
