single bottom
JERRY CRIDER
01-29-2004 10:56:20
I am using a single bottom plow with a 9n. My plow has a colter wheel but no room on the plow to attach a stablizing bar. Should I chain it off or is there another way . Last year I plowed a new feild that I had mowed and disked .I had a lot of trouble thanks for any imput.
Bob Brown
02-13-2004 22:04:05
 Re: single bottom in reply to JERRY CRIDER, 01-29-2004 10:56:20
I should have a manual for that plow that I can copy for you. Email at
Jerry D in NC
01-29-2004 13:03:11
A plow does not need a stabilizer bar if it is setup correctly. A single plow is very forgiving in its setup but if you get it properly aligned it will jump in the ground and follow perfectly. You need to get the manual for your plow and check the adjustments
