Hey Hugh,,,value question?
Jim in michigan
01-29-2004 07:04:59
Hugh,, do you know what a Farmall number 27V or possibly it was a 25V ( its under the snow so I cant check) semi mounted sickle mower would be worth. It is in excellent shape and it has the cables and pulley for use on the Super C touch control....Thanks,,,,Jim
Hugh MacKay
01-29-2004 12:35:07
 Re: Hey Hugh,,,value question? in reply to Jim in michigan, 01-29-2004 07:04:59
Jim: Saw your note over on the Farmall page, decided to come to your original question. If you found one of those mowers either 25V or 27V in good condition they are a very good mower. We had a one back on the farm and used it on the Farmall 130. My 130 has fast hitch, so we just ran two 1/2x3x3 angle irons back from bolts standard drawbar usually mounts on. When we installed the mower we just dropped the fast hitch pull bar, and mounted mower to those angle irons, just as one would on the standard drawbar.
Your question on what it is worth, is one I don't have an exact answer for. I do know it would cost a lot to put a poor one in good shape today. The only problem we ever had other than wear parts was the bottom shaft on the pitman drive, bearings went. It is oil bath and not a large resovoir so a leak can spell trouble quite quickly. What I would do is look over all the wear parts on the cutter bar, knives, fingers, ledger plates, back wear plates and hold downs. Also look the shoes over quite well. Just go to a parts counter and price out those items, The value of the parts you don't need is what the mower is worth. You know what a completely worn out mower is worth for scrap. Just add the value of the parts you don't need to the scrap price. Therein lies the value. I expect you can buy it for less than that. Old tractors may not be a good buy but old inplements usually are.
Jim in michigan
01-29-2004 13:55:07
 Re: Re: Hey Hugh,,,value question? in reply to Hugh MacKay, 01-29-2004 12:35:07
This one just needs the pitman replaced,,and that is a 7 dollar part. It could use some knives replaced or even sharpened, but if I recall right it has some new ones in the wood box mounted on it,,,I dont use it as I have a JD mower that is almost identical to it that I use,,,,Thanks,,,Jim
