Cutting a corner with as Haybine
Kelly C
01-29-2004 06:16:07
Last summer I got quite good at making nice square corners with my Sickle bar mower. Ok well most of them any way. Thanks for the Info on that by the way Paul :-)
This year its the NH Haybine getting the cutting duties. So whats the poop on making turns with these? DO you just end up going in circles? I.E. rounded corners. I am sure I can figure it out with out asking, But it seems all the Farmers around take great pleasure in watching me learn :-) Might be able to save a few chuckles at the cafe if I had a clue 1st. Dont get me wrong they are supportive of me. They have helped me out alot. Ones letting me use his seeder next year. But you know how it is. Why supply chuckle matter if you dont have too?
Hugh MacKay
01-30-2004 08:03:16
 Re: Cutting a corner with as Haybine in reply to Kelly C, 01-29-2004 06:16:07
Kelly: Seems like some people don't like quick turns with a haybine. When you mow a field, doesn't matter whether it is 5, 25, 50 or 100 acres or indeed what shape it is, " every width of that cutter you have to turn and go the other direction, that is a fact no matter what latout you use in mowing." Every foot or minute you travel with that cutter in the raised position it is usless wear on that machine. Making large sweeping turns with cutter raised actually creates more time with activation on your U joints. Lubrication is the key. The U joint was engineered for that sharp turn.
As far as making turns with rake and baler, I had no problem with those. Most of my crop was picked up by 1066 with duals and NH 890 forage harvester with wagon in tow. That harvester had the long tongue for use with duals. My operators could do those 90 degree turns and never miss hay.
Because of 1066 and 890 or 560 and round baler my 656 and NH haybine often went 16 hours per day just to stay ahead. And heaven help the operator that didn't have that haybine in hay 100% of the time. I fully realize I should have had larger haybine for some jobs. I however didn't like what was on market in those days wider than 9 feet. I raked and turned hay with two IH rubber tired side delivery rakes with 4x36 wheels on front and casters behind with SA and 130. Those rakes were 1940s vintage, and they didn't thrash leaves either.
TP from Central PA
01-30-2004 06:30:13
I agree with Rick, save your driveline and work in lands..... .....Mowing square corners is non-sense IMO since you can't rake them as nice anyhow. We have lanes around most of our hay fields here, so I rarely have to worry about it, but in a few I only make the first four rounds with square corners and then lift the haybine on the rest of the rounds on the headlands. Square corners is hard on drivelines, no doubt about it. Like I said, you can't rake and bale them so why bother..... ..... ..... ..... We roll our Alfalfa to dry it with a rake so you can't get to tight with the haybine or you'll have damp spots that didn't flip and it will mold later on. I haven't see to many guys make square corners though the entire field other than the first four rounds or so..... .....
Hugh MacKay
01-30-2004 07:17:27
 Re: Re: Cutting a corner with as Haybine in reply to TP from Central PA, 01-30-2004 06:30:13
TP: Bullfeathers.
Rick
01-29-2004 13:06:28
Do it in lands save your pto knuckles.
Hugh MacKay
01-29-2004 13:59:54
 Re: Re: Cutting a corner with as Haybine in reply to Rick, 01-29-2004 13:06:28
Rick: I had my first NH haybine, a 460 for 17 years, mowed 400-600 acres every year, replaced one set of U joints. A 90 degree turn at 3.25 mph is about 2 seconds. The same turn making a big circle is 45 seconds with tractor and machine at 35 degrees. The wear is actually less on the quick turn. Grease is the answer my friend.
Rick
01-29-2004 19:06:39
 Re: Re: Re: Cutting a corner with as Haybine in reply to Hugh MacKay, 01-29-2004 13:59:54
Thats fine. I use center pivots
Hugh MacKay
01-29-2004 12:57:58
Kelly: Remember when I told you, that you should buy a 656. Look at the advise you have, all the guys with the pre 1958 Farmalls have hay missed on the corners. All except Wolfy. This is the beauty of the newer Farmall wide fronts. You have wide front so it doesn't ride the mowen hay, but you also have the manuverability of a narrow front tractor. Like Wolfy, I have mowed many many acres, never touched the hydraulic lever from the time I entered the field until leaving field with 656 and 9 ft haybine. Even on points, I could do 180 and back down field with out lifting cutter bar. I have mowed 25 acre fields touching nothing but the steering wheel and TA lever, ocasionally a light toe on the right brake. You went and bought that 400, and now you have as much money invested as you would in a 656D. OOooHhh Kelly, when are you ever going to listen to me.
wolfy
01-29-2004 08:33:13
With a haybine, when cutterbar is a few feet from end casually crank steering wheel right to the limit- drawbar will pull header to finish the cut-about the time you've cranked to limit right, just casually crank to near limit left, then straighten wheel. I also lift cutter head just as it begins it's backwards swing & lower head when it reaches it most rearward swing. Cutterbar goes backward as you continue driving forward because you are making your drawbar do that to the haybine. The lifting & lowering eliminates the backward sweeo of cutter from bunching any hay-also a little easier on skid shoes. If any problems, try this: When about 6 feet of grass left to be cut, close eyes, crank wheel to limit right, when reach limit crank to limit left, and then open eyes & steer straight. If that doesn't work, your drawbar is set wrong. The correct drawbar length is essential. I have entered field, put 460 in 2nd high side, mowed non-stop for hours- never touched gear shift, torque or throttle til the fielf is done. Never an unmowed blade, never a bunched bit of hay.
Jim in michigan
01-29-2004 07:02:24
Kelly,, I have managed to make good square corners with my Haybine, but it seems there is always a small poof of hay left at the corner,,so when the field is cut then there is a large X crossing the field, I just cut the X after I am done in the feild and leave that hay for the deer. when I do rounder corners then it doesnt leave the X ,,,I generally make rounder corners because the PTO doesnt chatter that way on the baler and it is easier to rake,,Jim
Adam R
01-29-2004 06:55:44
Kelly I usually could cut square corners perfict 90s with a JD2440, and a 489 Nh, but that was when I was cutting for my Dads friend.
Now when I cut with the 450 or the M I cant make a perfict corner but can come resonably close. When cutting with the M (it has a wf) I come up to the corner and start turning when the right front wheel is even with the left side of the prevous windrow I turn it hard then when the right wheel is next to the uncut hay I straighten out. With the 450 (NF) I come up to the corner and pull the Torq back and bring the front end up on the left side of the prevous windrow, turn hard and when the front end is in the middle of the windrow I straighten out. then put the Torq back in direct. For you I would use the 400 being that it has a Wf TA and Live PTO, it will be much easiar for you to learn how to handle the Haybine on. IT thake some leraning for each Haybine but once you get 15 acres under your belt you should be pretty good with it.
Adam R Also is the PS on your 400 in good working order becaues if it steers somewhat hard now it will be a bear when cutting, I know thats why the M went back on the Haybine after first crop.
JMS/MN
01-29-2004 06:44:14
You can go round and round, but you could also cut the field as you would with a swather. Make four rounds to give you end rows, then split the field every so often. I'd split a square 40 about every 7 acres. Splits are cut counterclockwise, balance is cut clockwise, similar to laying out a field for plowing. Adjust cutting pattern in odd-shaped fields. Less pto strain with the easier corners. Need to follow the same pattern with the baler. With some forethought you will end up switching wagons on the near end of the field, instead of the back side.
D
01-29-2004 08:43:54
 Re: Re: Cutting a corner with as Haybine in reply to JMS/MN, 01-29-2004 06:44:14
Agreed. This also makes it a lot easier to rake, particularly if you're doubling up windrows, because when you get to the rows you can start 4 rows in, kick it to either the left or right depending on what the rake is, then go to the 1st row when you get to the end then you just go down the field moving on to every 2nd row as you go
