My take on it: To make really good alfalfa, you need a haybine or a crimper. Without hyd you would need to cut the hay with a sickle mower, & crimp with a crimper. Not nearly as much fun as a haybine. In fact, downright frustrating some somes. ;) Sounds like a few older haybines do not need hyd - going to be hard to find one with good rollers. You can mow alfalfa with just a sickle mower, no crimping. However, it will take an extra day to dry, you will lose more leaves, and it will look like long stringy hay instead of fine fresh alfalfa bales. Depends on where you want to be. Some areas of the country use tedding to help cure the hay, others do not. I'm not familiar with it; some people can't make hay without a tedder. Depends on where you are. To rake, most any old siderake will work, good NH 256 units bring $1400 or double, while some old Case or NI units bring $50. If you scrimp money, scrimp on the rake. To bale, I would want a good older NH or JD square baler. Do not scrimp money on the baler. Do not buy some off brand no one else has heard of (or can fix, or has parts available, or misses tying every 5th bale...). To load bales, will you drop in the field & get later, hand load on a hayrack while baling, bale thrower & bale rack, or a bale basket? Drop in the field is a _lot_ of work for 1 person on 10 acres. Loading the hayrack requires 2 people, and alfalfa is very time sensitive - bale an hour too early & you have mold, bale 2 hours too late & you have a bale of stems with the leaves laying on the ground swome days. Do you have access to 2 people when needed? Bale thrower will cost more, more maintenence. Bale baskets are pretty simple, but harder to find. Storage - you need a shed or barn to hold your bales, or it will all be wasted anyhow. Grass hay is really about the same, it will dry out better than alfalfa without crimping, but crimping helps save grass leaves, drying time, etc. Soundsl like you had questions on haybine/ crimper? A haybine is just a combination of a sickle mower & a crimper with a reel on it, so it works much better. (Ignoring rotory cutters & discbines, as this is 10 acres...) Below is a link to a Haying FAQ that has evolved over years on the internet, and answers a lot of questions on hay making from land to fertility to equipment to storage. --->Paul
