using a 3 point scoop
playing in the
01-26-2004 22:53:20
I need to move some ground ( not lose dirt) reguler flat ground with grass on it.And I need to fill in a ditch only thirty feet away from the ground I want moved. My question is, do you think I can do this with a 3 point scoop? I've never used one before or seen one used eather. Does anyone out there has experance with using one? well well do they work? Next question: I have fast hitch tractor with 3 point adapters I'm not sure that it will be able to rase the scoop up high enough to dump! Any Ideas?.Thanks
Smitty
01-28-2004 14:13:26
 Re: using a 3 point scoop in reply to playing in the dirt, 01-26-2004 22:53:20
Have you considered using a box blade with scarifier teeth?
I have both a three point scoop and a heavy built 7' boxblade that I use behind my WD and WD45. In my opinion the scoop is better suited for moving piles of loose dirt / material, although I have dug large holes with them. I liked the box blade better because it is wider than my tractor tread. With those scarifier teeth, you can peel off the top inch or two of ground, until the box is full, then just float your three point while you drag the box full of dirt whereever you need to move it. If you are filling in a ditch, you could straddle it with the box blade; or if it is a big ditch, you could raise the box and dump the load in front of ditch, then turn around and back into it to backfill the ditch.
Just a suggestion...
playing in the dirt
01-29-2004 10:24:21
 Re: Re: using a 3 point scoop in reply to Smitty, 01-28-2004 14:13:26
Smitty..... I thought of your idea myself, but I was worried that when I scalped off the dirt then tried to tranport the dirt over to the ditch that I would have to lift the box up a little or else the teeth would keep digging in. And when I lift the box up a little willn't I lose the dirt out of the bottom before I get to the ditch? Would I have to remove the teeth every time so they willn't dig in than put them back in when I go to scrap again? I would like to use a scraper box on this project because I could use one on a lot of little jobs around here, and would only need the scoop just for this one job. Thanks ahead of time!
TW
01-28-2004 04:09:54
I bought an inexpensive one a about 10 years ago at the local Fleet Farm Store. It was rated for a smaller category 1 tractor (30-35hp). I think I paid about $200.
Well I couldn't resist the temptation to use it behind my JD 2520 (60 hp category 2 tractor). It actually worked quite well but it has its limitations. If you don't expect it to perform like a front end loader you will probably be satisfied.
I made the mistake one day of digging into a dirt pile that was partially frozen. The hydraulics on my 2520 were more than the dirt scoop could handle. I bent the frame into pretzel shape. I only have myself to blame.
RayP(MI)
01-27-2004 16:16:55
Have one I use on a Farmall 200, 2pt with worksaver 3pt adapter kit. Had to shim the 3pt pins on the bucket to fit the 3pt arms, and I have two different top links, one a "shorty". I've used mine quite a bit. It's not as versatile as I'd like, but it does get the job done. loading at levels below tractor tires can be problematic. But for ocassional use, it sure beats a shovel and wheelbarrow.
Geo in SD
01-27-2004 05:33:50
A scoop should work real well for this job. Whether it will work with your 2 point adapter is a question I can't answer. If it is workable, you should be able to load the scoop and unload by driving in a circle pattern, won,t even have to stop. I've moved a lot of dirt with a Dearborn scoop and Ford tractor in various projects. Doesn't take long to move a lot of dirt, and it's fun, too.
Scott
01-28-2004 13:37:23
 Re: Re: using a 3 point scoop in reply to Geo in SD, 01-27-2004 05:33:50
Is this the same cussed 3pt scoop that I have tried to use on numerous occations? Like a bucket on the rear, trip to dump? The one I have must be a POS then, cause it won't dig without stopping the tractor dead in it's tracks. Only way to move dirt with it is to hook the Allis up to the plow and turn it over, then the scoop will pick it up on the Ford.
paul
01-28-2004 18:28:38
 Re: Re: Re: using a 3 point scoop in reply to Scott, 01-28-2004 13:37:23
You have clay.
--->Paul
