new holland 66 baler
bruce
01-26-2004 15:27:25
What would make my 66 consistently tie one side of the bales tighter,resulting in crooked bales? Thanks.
M guy
01-27-2004 10:50:17
 Re: new holland 66 baler in reply to bruce, 01-26-2004 15:27:25
Check yer wadboard an' see if it's set proper like the BOOK says. Mguy.
Bob Semrau
01-27-2004 09:06:26
You might check the wedges on the sides of the bale chamber that hold the bale when the plunger isn't there - if one is gone, that side of the bale will pop forward, making the twine on that side loose. After the bale is tied, but while it is still compressed, is the twine slack on one side ?
Bruce
01-27-2004 09:56:57
 Re: Re: new holland 66 baler in reply to Bob Semrau, 01-27-2004 09:06:26
Thanks gentlemen,I'll have to check this season to see if the twine is tight or slack on one side Bob.I have gone through the book and set all the adustments.I have not checked the wedges in the bale chamber.
Butch
01-27-2004 04:19:36
Been a while but we had a 66 for many years. Comes to me that getting the bales square has something to do with the wad board penetration into the chamber, assmuming you have the tensioners evenly adjusted. I belive the wadboard is run with a roller chain and is adjusted in or out of the chamber by slipping the chain over the drive cog. Like I said, been a few years.
BFarr
01-26-2004 18:16:24
Several things come to mind....windrow to small..feed rate off spec...different spring tension in rear..plunger speed off spec.
I would try each of these in order..when I ran 66s they could be cured of this.
Let us know what you find out
