John Deere disk parts
Ron
01-25-2004 12:40:27
Has anyone have any info on where you could get parts for a set of john deere wh 53 offset harrows?
Tom
01-25-2004 21:16:22
 Re: John Deere disk parts in reply to Ron, 01-25-2004 12:40:27
I also have a John Deere Model WH 76, which means 7 foot 6 inches; has 10 disks of 9 inch spacings = 90 inches (hence the 76). Your disk must have 7 disks in each gang on 9 inch spacing, hence 53 = five foot 3 inches or 63 inches. I am completely rebuilding mine, hav it in many many pieces now. My JD dealer has parts lists in the computer and most stuff is still available. What are you looking for?? The Model WH were made from about 1956 up into the 60s; not sure when production stoped. Mine is made in Canada and is Serial Number 02. They came with ball bearings with repalceable triple seals, and then some came with the old "white iron bearings" which just kind of a sleeve thing. Mine has the ball bearings. Post back.
Ron
01-28-2004 05:28:14
 Re: Re: John Deere disk parts in reply to Tom, 01-25-2004 21:16:22
Tom I am looking for a half spool on the front left side. I contacted my jd dealer and they didn't have any info. My serial # is 01
Tom
01-28-2004 06:11:01
 Re: Re: Re: John Deere disk parts in reply to Ron, 01-28-2004 05:28:14
Ron, The half spools you are talking about have a "short" end and a "long end". JD calls them "Sleeve, bearing, short" or "Sleeve, bearing, long" The parts list my JD dealer printed out for me shows; short = DT-52-W for one spool size and W-10756-W for the other spool size. Long DT-53-W or W-10755-W. My JD dealer has complete part lists in the computer for this harrow. The printouts say "(PC536) Model WH Wheel-Type Offset Disk Harrow". Don't know why your JD dealer is having problems, mine is Saginaw Implement in Rhome Texas 817-430-1165 and ask for Charlie, tell him that Tom Fletcher referred you to him. Let me know if you still can't find out anything.
Ron
01-29-2004 05:48:36
 Re: Re: Re: Re: John Deere disk parts in reply to Tom, 01-28-2004 06:11:01
Thanks for the info Tom on my way to JD dealer!
bryan g in mo
01-25-2004 14:55:38
try your local John Deere dealer,I recently got parts for a RWA I think was the model, disc and they had all the parts in stock.
paul
01-25-2004 13:43:47
I've not even heard of that model, but Shoup has a lot of disk parts. They are on the web, I often get blocked if I try to post the web site here.
--->Paul
JMS/MN
01-25-2004 15:37:02
 Re: Re: John Deere disk parts in reply to paul, 01-25-2004 13:43:47
www.schoupparts.com or 1-800-627-6137 for free catalog.
