271 nh
jf
01-25-2004 12:13:08
a new hollsnd 271 square baler is coming up for auction-anybody have any knowledge of these?Thanks
steve
07-20-2004 18:28:28
 Re: 271 nh in reply to jf, 01-25-2004 12:13:08
I'am looking at buying a 271, but one of the knotters are not working. any idea's ?
TDK
01-25-2004 19:25:22
We've used one for over 30 yrs. with no problems.Only failures was two worn out flywheel bushings,at appox. cost of 16.00 & a couple hours labor.Would highly reccommend it!
paul
01-25-2004 13:59:04
It is the exact same baler as a 270, save for the hitch - the 271 has a better hitch, with an extra flex in the pto driveline.
I have a 270, baled 2000-5000 bales a year for us since I was knee-high. That's 35 years or so. Very little problem with it ever, ties 497 bales out of 500 unless I'm doing something wrong. Dad & I are not known for good maintenence either, other than lots of grease.
They are a little slower than the newer balers, works well with a 35 hp tractor, won't bale any faster with an 85hp tractor.....
Also the 270 doesn't let the tractor get over to the left very far, a wide tractor will run on the windrow which is not good. Perhaps the 271 is better at this. Works great with an ICH 300 tho - need the right wheel all the way in. :)
--->Paul
Josh
01-25-2004 12:26:43
It is an older baler, but in my opinion one of the best made. It has good capacity for a small baler, is very easy to work on, and pulls easily. I think it is one of the best and you won't go wrong with it.
