Tandom Disc Harrow
Benj. J. Joe Br
01-24-2004 16:37:38
Hello Everyone, I want to build a 54 inch wide Tandom Disc Harrow. I can build it in single mode also. I have several questions. Will a 19 horsepower four wheel drive Kubota B8200 have enough power to pull it? What angle should the disc harrow be set? The design is one that I'm copying. It shows a fix angle. How critical is it to have the angle adjustable? It would be easier to build it fixed, however if adjustable is better. I'm not against changing the design. All help is appreciated. Thanks, Benjamin J. "Joe" Browning [email protected] Longview, Washington 98632
Why Double Post
01-25-2004 21:07:09
 Re: Tandom Disc Harrow in reply to Benj. J. Joe Browning, 01-24-2004 16:37:38
Saw your post also in Tractor Talk. Where would you like to receive input??
01-26-2004 12:36:32
 Re: Re: Tandom Disc Harrow in reply to Why Double Post, 01-25-2004 21:07:09
Hello Why Double Post AKA Forum Police, The reason is quite simple, not all individuals read all the posts on all the different forum
sid
01-24-2004 19:14:38
I would think you would have plenty of power. I would not know what angle to suggest but I would prefer to have the adjustable angles for different conditions. the greater the angle the more aggressive the cutting action of the disc lesser angle for a smoother seed bed on the final pass.
