Servis brushhog
Bob
08-02-1999 18:45:32
I have a brushhog mower I need info on. The nameplate on it says Servis Equipment Co. Model 060?. Serial # 8378. On the gear head it says SC 59, also Permaster. I would like to0 check out parts availability. The man I bought it from was using wheel bearing grease for lube,I tryed 90 weight gear lube, can't afford aquart an acre.
TONY MURAY
05-18-2002 10:11:16
 Re: Servis brushhog in reply to Bob, 08-02-1999 18:45:32
MY BRO IN LAW HAS RECENTLY PURCHASED A TILTING SCRAPER WITH THE SERVIS EQUIPMENT COMPANY NAME ON IT. IT IS MISSING THE PIN THAT KEEPS THE BLADE FROM TILTING. THE WHOLE APPARATUS THAT KEEPS THE BLADE FROM TILTING OR KEEPING IT TILTED IS MISSING. IS THERE PARTS THAT WE CAN ORDER TO FIX THIS PROBLEM. THE SCRAPER IS A LITTLE RHINO MODEL NUMBER E3WM
jcj
08-09-1999 13:58:53
Bob, Just read your post, better late than never.
I have the address for Servis-Rhino for you,,,,,
Servis-Rhino
P.O. Box 712
Seguin, TX 78156
(830)372-3080
They can get you parts or tell you where the dealer closest to you is located..
Hope this is what you needed jcj
Buford
08-03-1999 23:34:58
The company was Servis-Rhino for a good number of years but I believe they have been bought out again. I don't know where you are located, but in our area (Oregon) parts are readily available from any of the major ag implement dealers. If you can't get anywhere with them, let me know and I can do some research for you.
Tom A
08-03-1999 05:16:59
I'm on a similar search, and I think eventually I'm going to make a list of all the manufacturers and phone #s I've called. But until then, I did find a really neat web page that may help you get started. It's at: >Link
Lots>Link of resources for all kinds of farm-related stuff. Good luck in your search, Tom
