McCormick #46 baler
Devin Brewer
01-17-2004 19:03:06
I have an opportunity to get an old #46 MCCormick square baler. I know the man who owns it now and I know it has been shedded for approximately 20 years. It hasn't baled any hay in that time. I also know that it had only one previous owner who maintained the baler extremely well. The baler looks to be in great shape. However, the man advised me that it will tie only on one side of the bale and not the other. I know absolutely nothing about working on knotters. What could be wrong? Are there still parts available for this machine(knotters)? How expensive would new knotters be if that is what is needed. Help!!
I can get the baler for free. I just don't want to drag it home if I can't get some use out of it. I've got too much junk already! Thanks in advance for any suggestions.
Devin
mike
01-25-2004 16:59:45
 Re: McCormick #46 baler in reply to Devin Brewer, 01-17-2004 19:03:06
There are bearing followers on each knotter, they are behind a nut and spring, try tighting the nut a little. If it still doesn't tie you may need to replace the follower. They are about $75 to $100 for a pair available from CaseIH dealer. These are an excellent baler and they have a gear driven knotter not chain driven like the New Holland which can go out of time.
Lanny Smith
06-10-2004 10:17:06
 Re: Re: McCormick #46 baler in reply to mike, 01-25-2004 16:59:45
Can any one tell me how to thread the twine on a McCormick 46 baler. Or at least the knotter.
Leroy
01-19-2004 19:07:37
Also check for up-down movement on the plunger, if the slides are worn it will cause what you describe, had one from about 77-81 when quit dairying, when we bought it it had had a total whole new plunger put in because of that problem, you will find the same thing with any bake or model baler of any age
Rick
01-19-2004 15:33:35
i know where their is a IH 37 baler in good baling shape if that would help you out any
Craig Duguay
06-23-2004 19:56:59
 Re: Re: McCormick #46 baler in reply to Rick, 01-19-2004 15:33:35
i have a McCormick #46 baler, and i am wondering if someone has a book, or manual, or any info about them.
Devin Brewer
01-19-2004 17:02:10
Rick,
Where is the model located you are referring to. I might be interested if it is close to the western KY area. Thanks
Devin
Rick
01-20-2004 07:17:44
 Re: Re: Re: McCormick #46 baler in reply to Devin Brewer, 01-19-2004 17:02:10
Devin; It is located in southeast Iowa
Devin Brewer
01-20-2004 10:49:57
 Re: Re: Re: Re: McCormick #46 baler in reply to Rick, 01-20-2004 07:17:44
Rick,
That's a little far away for me, but thanks for the information. Best wishes.
Devin
Rick
01-20-2004 11:34:25
 Re: Re: Re: Re: Re: McCormick #46 baler in reply to Devin Brewer, 01-20-2004 10:49:57
No problem. I do have a fellow that would be happy to haul it to you thou if that would help.
Delbert
01-18-2004 06:08:22
Needs twine knifes shapened and adjusted . You will need to remove twine knifes and put small washers behind them to make it cut twine quicker. Will take some tinkering to get it right but will work. Also the twine bill are probaly wornen out and need replaced. They can be gotten at csae ih dealer but are pricy. May just need cleaned up real good. And don,t run this baler to fast no more than 20 to 25 strokes per minute run to fast and it won,t tie. Ground speed depends on the amount of hay you are feeding it. They make as nice a bale as any baler out there. Also check hay dog springs there are 4 of them and if broken need to be replaced. Can buy a spring at local hardware store for this purpose. Check spring on plunger stop also. After setting all this time it could have some things froze up. Sounds as if the price is right. All the best to you and yours.
Devin Brewer
01-18-2004 16:53:21
 Re: Re: McCormick #46 baler in reply to Delbert, 01-18-2004 06:08:22
Thanks Delbert for the advice. I will give these items a good going over and see what happens. Thanks again.
Devin
